1989 Chevy C/K 3500 Aux Fan Cycles
CHEVROLET
Hi everyone, I have 1989 Chevy ck3500,454, manual stick with 85k miles on it. It has a factory auxiliary fan designed to come on when the engine coolant reaches a certain temperature. My problem is it's 70 degrees outside and the fan is constantly cycling off & on at idle or any other speed when it shouldn't be on at all. It may stay on for a minute, then off for a minute. I've been reading about a fan switch, is this what I am looking for to fix it & if so where is it located, thanks for any help, much appreciated.
Dec 13, 2006 at 5:13 AM
I think the the switch you are referring to is fan relay. This relay should be controlled by a temp sensor that will cause the relay to pick up and send power to the fan. If I had to make a guess I would say that the temp sensor is defective and causing the fan to go on went it is not suppose to. If you trace the wires from the fan to the relay to the sensor, you can then test it and replace it.
Backyardmechanic :)
Backyardmechanic :)
Dec 13, 2006 at 6:16 AM
Suggested Repair
Trace the auxiliary fan wiring from the fan to the relay and temperature sensor. Test the coolant temperature sensor and fan relay; a faulty sensor is the likely reason the fan runs when the engine is not hot. Replace whichever part testing shows is defective.
Conversation Summary
The owner of a 1989 Chevrolet C/K 3500 with a 454 says the factory auxiliary electric fan cycles on and off at idle and while driving in about 70-degree weather, when it should not run. They asked whether a fan switch is the fix and where it is located. The expert said the fan is controlled by a relay triggered by a temperature sensor, suspected a bad sensor, and advised tracing the wires from the fan to the relay and sensor, then testing and replacing the faulty part.
