2 GM mechanics haven't a clue. I did replace the fuel regulator because it was bad and was told that it might have been the problem, but it has happened again. I have plenty of fuel line pressure. could I have a faulty fuel pump? :cry: :arrow:
2000 Chevrolet Silverado Cranks No Start
Suggested Repair
Test the fuel pump rather than replacing it on guesswork. Change the fuel filter if its service history is unknown, inspect the fuel lines for leaks or kinks, and use a fuel-pressure gauge to confirm pressure is within specification while running and does not drop excessively after shutdown.
Conversation Summary
A 2000 Chevrolet Silverado 1500 Z71 with a 5.3L engine intermittently cranks but will not start, then starts after sitting about 20 minutes and runs normally for months. The fuel-pressure regulator was replaced and line pressure appears adequate, but the problem returned. The expert says a faulty fuel pump is possible but must be verified by inspecting the fuel lines, considering a fuel-filter change, and measuring both running and residual fuel pressure.
