1940 Chevrolet Overheats Under Load
Hope this helps Backyardmechanic :roll:
Thanks for all the help
Suggested Repair
Repair or replace the cracked cylinder head, replace both head gaskets and seals, and repair the damaged valves. After reassembly, verify coolant flow and that the cooling system holds pressure.
Conversation Summary
The owner of a Chevrolet with a 400 small block reported rapid overheating under load after replacing the thermostat, hoses, and radiator cap. Idle temperature stayed near normal, coolant remained in the system, and the oil showed no coolant contamination. Advisors suggested checking steam-hole alignment, water-pump circulation, radiator restriction, debris, belt tension, and clutch-fan operation. The owner later found one blown head gasket and a cracked head with valve damage, along with stop-leak residue, and planned to repair the heads and replace the gaskets and seals.
