1996 Other Chevrolet Models Water pump replacement for 7.4L
1996 CHEVROLET
68,000 MILES • V8 • 2WD • AUTOMATIC
STEPHEN HOWARD
Parts house needs to know if fuel system is SFI or TBI. I gave them eng code J from VIN but they are still not sure. Also needed to know if water pump was normal rotation or counter rotation. I had to momentarly hit start and watch fan rotation, assuming clockwise or counter clockwise is viewed from front of engine. Do parts houses not have access to this info? I have Chevy Motorhome Chassis Servive Guide purchased in 1996 from Chevy dealer, Vin code breakdown shows eng code J is SFI fuel system, But I cannot see any fuel injectors on the engine. why would there be a difference in the water pump depending on the fuel system being SFI or TBI?
Jul 10, 2009 at 12:19 PM
HMAC300
  • 48,601 POSTS
if you have a thing that looks like a carburetor, then it's a TBI unit. The fuelinjection for that motor will have a largeunit going the whle length of the engine practiacally with the air input from the front. The difference in the water pump may be mounting points for different accessories.
Nov 8, 2009 at 9:10 AM
