Automatic Transmission
CHEVROLET
GGRIS
91 S10 Blazer 100K 4.3 V6
Transmission seems to slip while in Lock up in 3rd and 4th. Vibration also. If I he the brake to turn off lockup the is no slippage. Can I disconect the lock up?
Dec 13, 2006 at 11:45 PM
MATHIASO
  • 1,209 POSTS
You may have damage rear clutch causing slipping and vibration when your transmission is shift into any two forward gears.
do you have vibration when slippage stops?
or both them stop?
tell me more
mathiaso
Dec 14, 2006 at 4:20 AM
GGRIS
Vibration stops when the Trans go out of lockup but stays in either 3rd or 4th. Nor slippage at that time.
Dec 14, 2006 at 10:38 PM
MATHIASO
  • 1,209 POSTS
you have a slipping rear cutch problem.
the transmission may need to be remove to repair or replace the rear clutch.
ask your mechanic to perform a pressure test for comfirmation.
Dec 14, 2006 at 11:34 PM
