1991 Chevrolet S10 Blazer Lockup Slip
CHEVROLET
GGRIS
91 S10 Blazer 100K 4.3 V6
Transmission seems to slip while in Lock up in 3rd and 4th. Vibration also. If I he the brake to turn off lockup the is no slippage. Can I disconect the lock up?
Dec 13, 2006 at 11:45 PM
MATHIASO
  • 1,209 POSTS
You may have damage rear clutch causing slipping and vibration when your transmission is shift into any two forward gears.
do you have vibration when slippage stops?
or both them stop?
tell me more
mathiaso
Dec 14, 2006 at 4:20 AM
GGRIS
Vibration stops when the Trans go out of lockup but stays in either 3rd or 4th. Nor slippage at that time.
Dec 14, 2006 at 10:38 PM
MATHIASO
  • 1,209 POSTS
you have a slipping rear cutch problem.
the transmission may need to be remove to repair or replace the rear clutch.
ask your mechanic to perform a pressure test for comfirmation.
Dec 14, 2006 at 11:34 PM
Suggested Repair
Have a mechanic perform a transmission pressure test to confirm a slipping rear clutch. The transmission may need to be removed to repair or replace the rear clutch.
Conversation Summary
A 1991 Chevrolet S10 Blazer with a 4.3 V6 slips and vibrates in lockup in 3rd and 4th, but both symptoms stop when lockup is released while remaining in those gears. The expert diagnosed a slipping rear clutch and recommended a pressure test, with possible transmission removal to repair or replace the clutch.
