2000 Other Chevrolet Models rear tires wearing out and cuppi
2000 CHEVROLET
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SULLY39208
i have a prizm that when i first got it the rear tires were wearing out around 10,000 miles. there was a bent spindle that was fixed...i havent been able to rotate the tires like i should because im suspecting the car may have been hit or damaged from the rear. I've had some mechanics say they can 't balance the rear tires and some that can. The tires are cupping now and im suspecting that the rear tires are not lining up to the center of the car... I dont think the struts need to be replaced but i am willing to do that if the frame is not bent... any suggestions????
Aug 26, 2008 at 12:55 AM
SERVICE WRITER
  • 9,123 POSTS
You can start off by checking the alignment to see if there is a problem there. IF not then replace the struts and keep up on the rotation. If they are too cupped, then replace the tires.
Aug 26, 2008 at 1:26 AM
SULLY39208
i had one mechanic told me to take it to a body shop because the frame was bent...that was 3 years ago...ive had trouble rotating tires...dont want to spend more money if frame is bent...so try to have all the wheels aligned or try to align the rear-end???
Aug 26, 2008 at 6:15 AM
SERVICE WRITER
  • 9,123 POSTS
A wheel alignment should include looking at the rear. The rear gets straighten out first, then the front is adjusted.
What do you mean you had trouble rotating the tires? Couldn't get out the lugwrench or the cash ;-)
IF the frame is bent, it has to be straightened out first. You need to truley be able to decide how much you'll spend to get your car back in shape.
Just to throw numbers,
Say it takes $250 to straighten the frame ( I have no Idea what it runs)
Another $600 for struts, another $70 alignment, $200 for tires,
So for a rough idea its $1200...Make that $1220..( can't forget the donation ;-) )
Can you buy a car for $1200 to replace what you have in running shape with any other consideration included? My guess is probably not...so it's worth fixing from a financial standpoint IMHO.
Aug 27, 2008 at 11:20 AM
