1999 Other Chevrolet Models
GEOP68
  • 1999 CHEVROLET
Engine Mechanical problem
1999 Other Chevrolet Models V8 Four Wheel Drive Automatic 300.00 miles
cranks wont start. Getting fuel getting spark backfires through throttlebody
Monday, February 8th, 2010 AT 1:26 AM
HMAC300
  • 48,601 POSTS
If you have spark and fuel and it back fires hen check the distributor cap and rotor for damage/cracks. And if it's not that then it may be a timing chain problem. Also check te compression, if all cylinders are low then it's probably the timing chain. They would all be about 75 pounds or so if the chain has jumped.
Friday, February 19th, 2010 AT 5:38 PM
