1994 Other Chevrolet Models Truck dose not have all its powe
1994 CHEVROLET
147,000 MILES • V8 • 4WD • MANUAL
GGR8BUCK
My 1994 chevy 1500 has been having a hard time starting out it idles ok and revs up but when i let the clutch out and start out it jumps and jerks really bad. Dose ok in higher gears and faster speeds. Then i go a 44 code for it running lean so i replaced the o2 sensor and it is still acting up. I all so replaced the plugs, distributor cap,rotor,and a new fuel fillter and i found two wires on the coil that had insulation off of them and where touching i really thought that would fix it but still not working very well.
Jul 26, 2010 at 7:34 PM
HMAC300
  • 48,601 POSTS
check to see how much fuel pressure you have if it's TBI then you should have 9-11 p.s.i. if it's cpi or port fuel you shoul dhave alot more
Jul 27, 2010 at 11:15 AM
GGR8BUCK
I checked the fuel pressure today and it is around 5psi so i am thinking i need to change the fuel pump i hope it is and it fixes it.
Jul 27, 2010 at 4:49 PM
