1988 Other Chevrolet Models Not getting Fire
TMORRIS
  • 1988 CHEVROLET
  • V8
  • 98,000 MILES
What would stop the fire from leaving the coil after it enters. There is fire going into the coil but nothing is coming out to make the engine fire.
Friday, October 17th, 2008 AT 10:25 PM
Pull the coil wire at the distributor and ground it and crank engine over do you have spark-if so and there's nothing at the plugs replace the distributor cap and ignition rotor
No spark at coil wire -check coil/distributor pick-up coil/air gap and igntion control module
Saturday, October 18th, 2008 AT 7:24 AM
