(I have a 85 Chevy C-10 chock engine pickup)
Are you saying you have a feedback carburetor. If you work the throttle, can you see gas squirt in the throttle bore?
Sometimes if there is an extended crank, I remove the airhorn, top of carb, see if there is gas in the float-bowl. If the fuel pump and filter are ok, maybe you need a carb kit. Your crankcase dipstick doesn't smell like gas?
I guess you can check for codes, it might show a lean system?
SPONSORED LINKS
Friday, April 10th, 2009 AT 10:58 AM
