1984 Other Chevrolet Models intermittent starting
NEWARKJOHN
  • 1984 CHEVROLET
  • 6 CYL
  • 159,500 MILES
Truck runs well once it starts - the prblem is intermittent starting - it will crank and crank but just won't start at times. Can you please help?
Tuesday, July 15th, 2008 AT 7:52 PM
KLSHIEL
  • 163 POSTS
Sounds like the starting system is fine. You have compression if the engine runs fine when it starts. That leaves fuel and spark. Check for fuel at the engine the next time it wount start. If your not getting fuel then the pump has stopped pumping for some reason. A bad pump, a bad ground on the pump are all likely. Also a bad crank sensor can cut power to the fuel pump intermittently. This will also stop spark so pull a plug and crank it, if you also don't have spark suspect the crank sensor, computer, or someother sensor to the ECM. Good Luck
Thursday, July 17th, 2008 AT 8:21 AM
