1970 Other Chevrolet Models 70 Chevelle Won't Start, Battery
MISSCONDUCT010
  • 1970 CHEVROLET
  • V8
  • 80,000 MILES
Here's the deal, my father restored cars and when he died we got 3 of them. We're trying to keep them running anf nice, but we have no idea what we're doing
We've put in a altinator, battery, voltage regulator and plugs. We've already checked the battery terminals and ground.
When I turn the key there's nothing, no clicking.
Acouple of months ago, after jumping the car, it start and run, but would not start again.
Thanks
Saturday, February 16th, 2008 AT 4:15 PM
BILLSCLASSICS
Try taking out the starter and having it tested-make sure all your connections are clean and tight
Saturday, February 16th, 2008 AT 4:21 PM
Do this be careful get a remote starter or use a screwdriver and hook it up on the starter solenoid purple wire terminal and the battery-did it crank over-if not check the purple wire for battery voltage. No power test the neutral safety switch and the ignition switch.
Saturday, February 16th, 2008 AT 4:26 PM
LOUT5369
  • 217 POSTS
Don't be surprized when you check for voltage at solenoid trigger wire if you don't have battery voltage, the circuit only has 7.5 volts to trigger solenoid not 12volts. This isn't a new car. Check the bulkhead connector on l/side fire wall, you'll see 2 square plugs the 1 closest to fender is lights, the 1 on mastercylinder side is ign. & Starter, make sure they are clean and tight. Good Luck, Lou
Wednesday, July 22nd, 2009 AT 7:58 AM
