1988 Chevy Nova car won't start
1988 CHEVROLET NOVA
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVEC1982
I have this "mystery" problem with my 88 nova. The problem is that after i drive my car to where i need to go, it wo't start when i try to turn it on again. The car won't turn over, i don't hear any clicking noises wheni turn the key, i have full lights, and they DON'T dim, so it's not the battery, you CAN jump it as long as it's car to car and not car to jump box, i just recently put a new starter in and that didn't really solve anything, anyadvice or if you have a solution i would be very grateful
-David Capano
Aug 12, 2010 at 12:41 PM
  • CAR REPAIR CONTRIBUTOR
Check and test the neutral start switch and ignition switch
Aug 12, 2010 at 5:09 PM
BOBALOU
David, I am experiencing the same exact problems. Your description of the "mystery" problem is the same as mine in my 1987 Chevy Nova.
I have replaced the ignition switch. I have also checked the neutral switch. Neither seems to be the cause of the problem.
Aug 12, 2010 at 10:18 PM
TO: bobalou
Try this have helper hold key in cranking position and check for power at the neutral switch black and white wire do you have it?
Aug 12, 2010 at 10:37 PM
