1978 Chevy Nova no pedal
1978 CHEVROLET NOVA
TGONZO
Brakes problem
1978 Chevy Nova 6 cyl Two Wheel Drive Automatic
I have changed out calipers, bake drums and even the master cylinder and can't seem to get any pedal pressure to bleed the brakes. I have bled the master cylinder and tried to bleed the brakes, but I can't get any pedal to build up so I can pump out the air in the lines. C an any one help me with what else I can do
Aug 15, 2010 at 4:29 AM
MIKE H R
  • 3,094 POSTS
Start with rebleeding the m,aster cylinder. then proceed to the praportioning valve and see if you can belled that. If so start with the front drivers wheeel and bleed that. If you can get the front wheel to bleed then you should be able to bleed the rest of thwe brakes. Check for any kinked lines as they will prevent the lines from bleeding.
Aug 24, 2010 at 1:47 AM
