Brakes problem
1970 Chevy Nova V8 Two Wheel Drive Automatic
Changed brakes from drum to disc on the front of my street rod. It has a 70 Nova front end and rear end. The master cylinder is an aftermarket with a boost. Put the new proportioning valve on. Calipers on front are bled, but rear has nothing coming out. Tried vacuum on rear wheels and nothing comes out. It's like it's sucking air. Cracked the fitting at the proportioning valve and got air and fluid. Should I open the rear lines and blow air through them? Don't know what else to do.
Oct 17, 2010 at 5:57 AM
