2003 Chevrolet Monte Carlo Rough Idle
AP515
2003 monte carlo 3.4 liter engine 94000 miles.
the car sounds like its struggling to stay on. i was told to replace the gas cap and give it some time. i replaced it one night at about 6 in the evening and at 10the next morning i started it again and the problem persisted. the engine shakes when i start it as runs as well. i would appreciate some help.
Jul 24, 2007 at 5:49 AM
CLY
  • 308 POSTS
Do you have any service lights coming on or flashing? The fuel cap may cause a service engine soon light but will not cause the car to run rough. One thing to check is the spark plug wires at the coil towers. pull them off one at a time and take a look at them to see if any are burnt or black.
Cly
Jul 24, 2007 at 9:57 AM
Suggested Repair
A fuel cap can set a service engine soon light but will not cause a rough idle. Inspect the spark plug wires at the coil towers one at a time for burnt or blackened ends, and note whether any service lights are on or flashing.
Conversation Summary
The owner of a 2003 Chevrolet Monte Carlo with a 3.4L engine reports a rough idle and shaking, as if the engine is struggling to stay running. Replacing the gas cap did not help. The expert says a fuel cap may trigger a service light but will not cause rough running, and advises checking the spark plug wires at the coil towers for burnt or blackened ends and whether any service lights are on or flashing.
