2005 Chevrolet Monte Carlo Key Stuck
EGIORCEL
have a 2005 monte carlo
key will not come out of key slot. and shifter will not lock into park or any other position.
Car will start and run fine, just when trying to shut off and take key out it will shut off engine but won't let the key come out or the shifter lock into park.
Jul 10, 2007 at 5:44 AM
MERLIN2021
  • 17,250 POSTS
Neutral saftey switch, may need adjustment. I think it's mounted on the tranny. Make sure the car can't roll before you get under it. The 68 had a habbit of jumping out of park! I had one an XL that kept eating the parking pawl...
Jul 10, 2007 at 8:48 AM
Suggested Repair
Inspect and adjust the neutral safety switch, which may be mounted on the transmission. Secure the vehicle so it cannot roll before working underneath.
Conversation Summary
The owner of a 2005 Chevrolet Monte Carlo says the car starts and runs, but the ignition key will not come out and the shifter will not lock in Park or any other position. The expert suggests the neutral safety switch may need adjustment and is likely mounted on the transmission, and advises making sure the car cannot roll before getting underneath.
