2003 Chevy Monte Carlo
PHILAUTOSERV
  • 2003 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 68,400 MILES
I have 2003 monte carlo and I have problem the car shots down when I driving and it does it more whe I turn to the left and also after I drive the car few miles and I stop and try to stater, starts but shots down and I try it again and runs. Please help.
Tuesday, January 12th, 2010 AT 10:12 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
First check the fuel pump fuse is not loose .. check the fuel pump relay is secure and good ..or replace relay ..check wiring to fuel pump and check fuel pump ... you could also check and replace CKP (crankshaft position sensor)
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_959.png
Wednesday, January 13th, 2010 AT 6:49 PM
PHILAUTOSERV
Hello I replace crank shaft sen sor and also I check my fuel pump relay and also I check ma fuel pump wires evething looks ok but I still have the problem. Thank you for you help
Thursday, January 14th, 2010 AT 10:03 PM
