1999 Chevy Monte Carlo Not much heat, temp gauge not workin
1999 CHEVROLET MONTE CARLO
65,000 MILES • 6 CYL • FWD • AUTOMATIC
CARLO99
My 99 monte carlo has had heating problems since i got it a year ago. The temperature guage only reaches 130 degrees or so when the engine is warmed up. At this point, i only get slightly warm air, but not enough to keep warm on a cold day. I have replaced the thermostat two times because i thought the first was faulty, but i cant imagine getting 2 faulty thermostats, so there must be some other problem. No codes to read, and coolant levels are ok. Please help...
Jan 20, 2009 at 4:14 PM
  • 110,244 POSTS
Have both new t-stats only heated to 130 degrees? If so, make sure you have the correct one in (190 degree). If you do, have the coolant temp tested with a thermometer to make sure it's actually only 130 degrees. If it is, the only thing that can cause it to warm up beyond that is if the t-stat stays closed longer. If the water is getting up to a normal temp, replace the temp sending unit. It must be sending a faulty signal to the gauge.
Let me know what you find.
Jan 27, 2009 at 5:39 AM
