2006 Chevy Monte Carlo temp. gauge says running hot, but th
2006 CHEVROLET MONTE CARLO
75,000 MILES • 6 CYL • FWD • AUTOMATIC
CITAN2000
ok so im having a few problems, that all seem to be related. first my a/c and heater both are not working properly during idle and only work well when i reach high rpm. Second, occasionally after turning my car off, ive been noticing that my fan continues running for 5-10 minutes. And lastly my engine temp. gauge has been moving up and twice last week gave me a message to turn engine off. Other times it just returned back to regualr temp. on its own. About 6 mos. ago i had similar problem with temperature gauge and brought it to a lube shop to check. They told me my car had a "bad code" and said they reset it for me. Now its doing same thing and im soooo lost of what it could be. Im trying to avoid spending unnecessary money.
May 4, 2009 at 3:21 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check coolant level and do cooling fans come on at idle when operating temp is met? Also do fans come on when AC is on? Check engine light on? if yes go to Auto Zone have codes read then post.
Let me know
Thanks for donate
May 5, 2009 at 3:23 AM
