1999 Chevy Monte Carlo Coolant/radiator
1999 CHEVROLET MONTE CARLO
101,333 MILES • 6 CYL • FWD • AUTOMATIC
JAMIE1986
How to find a leak in the coolant hoses? I suppose you could just watch. I was curious if there is a faster way to do this? And when draining the radiator is it kind of like changing the oil? What usualy causes the coolant to leak?
Feb 21, 2008 at 10:15 AM
DENNYP
  • 1,824 POSTS
you can have the system pressure tested by a mechanic. There should be a drain valve on the bottom side of the radiator for draining the coolant. Just drain it and fill it with a 50/50 coolant water mix.
Feb 23, 2008 at 5:09 PM
