1998 Chevy Monte Carlo STARTING
JASONSCHIEF
  • 1998 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 130,000 MILES
Turn the key 2 start car stalls. No big deal just turn the key again. When I did that it would not do anything. Still had power and the lights worked etc. Whated a couple of minutes tried again and it started. This has happend twice.
Friday, October 16th, 2009 AT 6:18 PM
  • 109,885 POSTS
It sounds like either the starter is going bad or the starter relay. When this happens, I need you to check something. Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. If you are getting 12+ volts to it and the starter doesn't work, replace the starter. If there is no power, replace the starter relay.
Let me know what you find.
Saturday, October 17th, 2009 AT 12:45 AM
