Did you check the neutral safety switch
try and move the shifter to N does it start and if so I would suspect the N/S switch or shifter cable out of adjustment
IGNITION SWITCH ASSEMBLY
Removal & Installation
Remove steering column.
Remove ignition switch mounting bolts. On models with column shift, remove "PRNDL" adjuster bracket and dimmer switch mounting stud. On all models, remove turn signal switch connector.
Remove pivot and pulse dimmer switch connector from ignition switch assembly connector on column housing.
Remove ignition switch assembly.
CAUTION:If replacing ignition switch, NEW switch will be pinned in OFF-LOCK position, remove plastic pin after switch is installed.
Ensure lock cylinder is in OFF-LOCK position.
Place ignition switch slider in far right position, and then move one detent to the left.
Insert a 3/32" drill bit into hole in switch to keep slider in position.
Insert ignition switch actuator rod into slider hole, and mount switch onto column.
Remove drill bit.
To complete installation, reverse removal procedure. Tighten mounting screws to 35 INCH lbs. (4 N.M)
SPONSORED LINKS
Saturday, November 7th, 2009 AT 5:55 AM
