1998 Chevy Monte Carlo help please
BJBALLA6
  • 1998 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 170,000 MILES
Ok my father currently drives my car to work, and it is leaking coolant. He says its not leaking from any hoses or the radiatior. When I drive this car it will idle pretty low, ususally around 700-900 which is low for this car. The breaks stiffen up pretty hard and I can barely tap them and lock them up. If I am on a deciently long trip like 5 or more miles and or depending on how hard its driven it will smell like the engine or coolant is burning, and lasty when im cruising and just let off the breaks it immediatley decreases speed rapidly without hitting the breaks.
could the coolant be leaking into the one of the headgaskets or manifold. Could anyone please help me, thanks.
Sunday, January 10th, 2010 AT 8:56 PM
DOCFIXIT
  • 18,828 POSTS
White smoke from tailpipe? Oil look normal? If no to both then headgaskets O.K. Probably intake having to add coolant frequently? Pull vacuum hose to brake booster signs of coolant?
Monday, January 11th, 2010 AT 10:27 AM
BJBALLA6
Their is white smoke and the oil is fine so far. And I can fill it up with coolant one day and I have to refill it like 2 weeks later.
Monday, January 11th, 2010 AT 10:36 AM
DOCFIXIT
  • 18,828 POSTS
Then intake gasket replacement
Monday, January 11th, 2010 AT 10:44 AM
