1986 Chevy Monte Carlo car stalls when braking in gear
NIGHTHAWK626
  • 1986 CHEVROLET MONTE CARLO
Engine Mechanical problem
1986 Chevy Monte Carlo V8 Two Wheel Drive Automatic unk miles
i need answer asap please. The car has 2b quadrajet carb on the 350sb. What happens is when I step on the brake, the cars rpm drop, then while stepping on the brake I put it in gear and the car cuts off, I know the problem could be very bad vaccum leak but could bad brake boost also be the problem, or what could I be looking at fixing here? Please help
Monday, January 4th, 2010 AT 3:11 PM
  • 109,885 POSTS
If it happens when you use the brakes, the first thing I would do is run a vacuum test on the booster and check the vacuum hose going from the engine to the booster.
Let me know what you find.
Monday, February 15th, 2010 AT 1:37 PM
ADAM DUTCHOVER
  • 8 POSTS
U probably need a new brake booster
Sunday, June 20th, 2010 AT 9:59 PM
Related Engine Stall While Driving Content
