At low speeds and idle the engine will die, it will restart immediately and idle or run for a while, then the engine will do it again. The fuel filter, plugs and wires have been changed. I also cleaned out the m.A.F.S. And the intake manifold. I regained some performance from the plug and wire change, but it will still die at low speeds. It runs great at highway speeds, and it does not idle rough. This is the 3.4 DOHC engine.
SPONSORED LINKS
Wednesday, January 20th, 2010 AT 8:03 PM
