Turn Signal
JENN1974
I just bought this 2002 Malibu yesterday afternoon. As soon as I drive it around town, both blinkers fail. I can get the hazard lights to work, sometimes. It is kind of like I have to hit the button just right. I have to have blinkers, what could it be and is it going to be expensive?
Also, it is smoking when I take off only......Is this a big deal, or what could it possibly be?
I need help!!!
Nov 20, 2007 at 12:16 AM
  • 75,988 POSTS
Have the Turn/Hazard flasher unit check and for the smoke if its blue-your burning oil, Black rich fuel mixture and White your burning coolant.
Nov 20, 2007 at 12:20 AM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Tue Nov 20, 2007 8:38 am
Subject: Burning white
It is burning white......kinda smells like coolant....is this a big deal? What would cause that?
I am worried about the financial aspect in repairs.....I think it is probably the turn signal flasher, too...is that expensive?
I am worried, 33, SF and I know nothing about cars!!
Get it in and have the tests below done -could be a blown headgasket
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 20, 2007 at 12:48 AM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Tue Nov 20, 2007 8:51 am
Subject: Blown headgasket??
WOW...............
The car is not overheating....wouldn't that make it overheat?
You need to verify exactly what color it is. White smoke during initial cold starts could be condensation-Once the engine comes up to its normal temperature and its still there-the coolant is being burn in the combustion chamber. Probable Causes: Blown Headgasket/ Crack head or block
Nov 20, 2007 at 1:06 AM
