ignition switch
RJCDEVILS
the ignition switch lock is broken so when the switch is off the key will come out but it won't lock the steering wheel or the shifter,so the power stays on and drains the batt. how can i fix this or disassemble ignition switch. for 2001 chevy malibu mil. aprox.120,000 6cyl.
Nov 29, 2007 at 1:23 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e0331a74fd="rjcdevils"]the ignition switch lock is broken so when the switch is off the key will come out but it won't lock the steering wheel or the shifter,so the power stays on and drains the batt. how can i fix this or disassemble ignition switch. for 2001 chevy malibu mil. aprox.120,000 6cyl.[/quote:e0331a74fd]
You have to take your key to your local dealer so they can do another ignition cylinder lock for you
Dec 6, 2007 at 11:34 AM
