Chevrolet Malibu Fan Only Works on High
1981CRAIG
The fan speed control in my wife's car is screwy. It just dribbles air out except on 5 then it blasts air out. Is this just a bad switch?
Aug 9, 2007 at 9:37 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the fan speed conrtoller. Located next to the blower motor under the dash on the pass side.Be sure your cabin filter is clean as well if the car is equipped with one. A clogged cabin filter will greatly reduce the amount of air out of the vents
Aug 9, 2007 at 9:43 AM
Suggested Repair
Inspect the fan speed controller next to the blower motor under the passenger-side dash, and check or replace the cabin air filter if the vehicle has one.
Conversation Summary
The owner reports the Chevrolet Malibu blower barely moves air except on the highest setting, which blasts air, and asks if the switch is bad. The expert says it sounds like the fan speed controller beside the blower motor under the passenger dash and also recommends checking for a clogged cabin filter.
