1999 Chevrolet Malibu Stalls Past 2000 RPM
WH1TEMAGE
I have a '99 Malibu, approaching 150K. Last month, I had to replace the catalyic converter. Now,a month later, my engine is not going over 2000 RPM, everytime I gun it in an attempt to go beyond 2000RPM, it flat out dies. I noticed that a bracket broke off of my tailpipe and is hanging lower than usual, but for the most part, still attached. I had it taken to a mechanic, and to my suprise, was told that the catalyic converter was bad again! In terms of regular tune ups, everything is current. But what else could be the cause of the engine not going over 2000RPM? Also, how can that foul up the catalyic converter? And finally, what can I do to keep this from happening again, as it is a troublesome (and expensive) problem?
Feb 6, 2006 at 5:46 AM
2CARPRO JACK
  • 11,533 POSTS
It sounds like the car has some kind of mixture problem to take out 2 cats. Have it comp diagnosed so they can watch the comp adjust mixture
Feb 9, 2006 at 5:45 AM
Suggested Repair
Have the vehicle computer-diagnosed so the air-fuel mixture and computer mixture adjustments can be monitored. A mixture problem is the likely cause of repeated catalytic converter failure and the engine dying above 2000 RPM.
Conversation Summary
The owner of a 1999 Malibu with about 150,000 miles replaced the catalytic converter, then a month later the engine dies when accelerated beyond 2000 RPM. A mechanic says the converter has failed again, and a tailpipe bracket is also broken. Tune-ups are current. The expert attributes the repeated converter failures to a fuel mixture problem and recommends a computer diagnosis to watch how the computer adjusts the mixture.
