2005 Chevy Malibu CV Joint
2005 CHEVROLET MALIBU
55,000 MILES • 4 CYL • FWD • AUTOMATIC
CALEXAND
I have had a "growling" noise in the front end on left hand turns, especially if applying the brakes. I had a front end alignment done and it was suggested that the noise might be the CV joint. Does this sound like the CV joint?
Feb 17, 2009 at 4:27 PM
CRZYDRVR
  • 432 POSTS
Usually when you hear a growling noise it is a wheel bearing. When a CV axle joint goes bad you normally hear more of a clicking and binding noise when turning. Keep us posted on your results
Feb 17, 2009 at 7:41 PM
PRUITTX2
what if you have already replaced the left fr wheel bearing with a new one,, still had the noise, went and got another new bearing, thinking the first one was bad,, and put in the 2nd new one,,, and STILL had the same growling noise??? Thats what I have going on. I have done autobody repair for 20 years.
I hand torqued the alxe nut, and can't think of why this is still growling at me,, unless the CV Joint is bad.
It will make a slighty louder growl while turning left,, and almost go away in a right turn. But going straight , its enough to drive you batty at highway speeds. The Bearing I took out was SHOT!! and came out of the knuckle in 2 pieces, So I was SURE that was the problem. Now I'm thinkin its got to be the driver side alxe,, of something in the tranny, as it Really seems to be from the left front, and not the right bearing going also. Unless sound REALLY travels thru the cradle that bad! ANY IDEAS before I snatch my self bald!???
Feb 28, 2009 at 7:36 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
replace the other side. i have been burnt by this a dozen times. its a wheel bearing noise, trust your gut but trust me when i tell you its the other side. let me know how you make out.
Feb 28, 2009 at 7:41 PM
PRUITTX2
thanx for the quick reply,, at least now, having done the job 2 times on the left side, I could do the right one in about 35 minutes. I had to go to a diff store, to get the first one warranted cause they only stock 1. Now I'll have to drive about 30 miles to get a second one for the right side,, but at $129 ea, I sure hope thats the problem. Nothing like throwing money at a car, to not have the problem fixed!!
I do find it hard to believe that its is the right side, When it sounds SO MUCH like its coming from the left front!! But I have been wrong before!
Feb 28, 2009 at 8:06 PM
MASTERTECHTIM
  • 4,750 POSTS
i use a tool called a chassis ear whre i actually hitch up electrical attachments to each wheel and listen with headphones while driving, thats how i found the first problem one. i was sure it was the left front and replaced it twice, the other 2 techs i worked with road tested and both agreed with me, i then hitched up the chassis ear and sure enough it was clear as a bell it was the other side.
Feb 28, 2009 at 8:11 PM
PRUITTX2
You fully rock,, man. Ill go get a new one and do the right side in the morning. I WILL post back the results,, and My wallet and wife sure hope your right!
Thanx again. Dave
Feb 28, 2009 at 8:19 PM
PRUITTX2
Yeah buddy,,, Went and got another Hub Bearing today,, Only took me about 30 mins to do this one.
Went for the test drive with fingers crossed,, and HOORAY No more noise!! 2 bearings, $260 and the Zone, I set of Fr brake pads,, $49 so $309. to fix my own problems instead of about $800 at the Stealership! Thanx for the helpfull advice!
Good Day!
Mar 1, 2009 at 10:21 AM
MASTERTECHTIM
  • 4,750 POSTS
when i checked my posts and saw you responded i was leary of opening the post for the 1 percent chance i was wrong. hooray glad to have helped man.
Mar 1, 2009 at 11:06 AM
