2002 Chevy Malibu Whats the problem?
BCALD44
  • 2002 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 89,000 MILES
The vehicle is making a loud whining sound and it gets louder the faster you drive. No problems while idling. It seems to be originating from the center or maybe from the passenger side. Also there is a noticable vibration during this. What cold be wrong? I'm torn between wheel bearings or CV joints. But then again I may be way off.
Wednesday, August 5th, 2009 AT 11:26 AM
  • 109,885 POSTS
A CV joint won't make that sound. A bearing can. Does the sound change when you make turns?
Monday, September 7th, 2009 AT 12:28 AM
BCALD44
  • 11 POSTS
Yes. When you turn left it gets louder. Turn right and it gets quieter. You thinking its a wheel bearing then?
Monday, September 7th, 2009 AT 9:50 AM
TAKECHARGESARGE
  • 92 POSTS
Bcald44,
Sounds to me as if the power steering fliud level has gotten so low the pump is trying to cavitate. Make sure the power steering fluid reservoir is serviced to proper level.
TakechargeSarge
Tuesday, September 15th, 2009 AT 2:29 AM
