2002 Chevrolet Malibu Losing Coolant
BEAR41361
My Malibu has 100,000 miles on it. Lately I have noticed that my coolent is always low. My warning light comes on and I add coolent and then its ok for awhile. I do not notice any leaks. Why do you think I'm loosing coolent?
Mar 6, 2007 at 11:30 PM
CHEVY22
  • 1,375 POSTS
you probably have a lower intake gasket leak , very common , i would have it looked at right away and check your oil for mily fluid , if you have milk get it to the shop right away as if you drive it like this it will fail
Mar 7, 2007 at 12:28 PM
Suggested Repair
Have the lower intake gasket inspected for a leak. Check the oil for a milky appearance and take the car to a shop immediately if coolant is mixing with the oil.
Conversation Summary
The owner of a 2002 Chevrolet Malibu with 100,000 miles reports the coolant level dropping and the warning light coming on, with no visible leaks. The expert says a lower intake gasket leak is common and advises checking the oil for milky fluid and getting the car to a shop right away if present to avoid engine failure.
