1997 Chevy Malibu Antifreeze light
137,231 MILES • 6 CYL • 2WD • AUTOMATIC
ARMANDO AVILA
Hi i have a 1997 Chevy Malibu.The antifreeze light is still after i just changed the liquids,I made sure that i purchased the right collant that was in the book.The engine light came on as well but turned off after i drove it around the block,what doi do about the antifreeze light?please help
Apr 24, 2008 at 2:32 PM
BMRFIXIT
  • 19,053 POSTS
Steps need to be taken
1. check and ensure you have no coolant leak
2. check intake manifold for leaks
3. check coolant level sensor it may be stuck and need to be replaced and or cleaned
Apr 24, 2008 at 2:49 PM
ARMANDO AVILA
[quote="BMRFIXIT"]Steps need to be taken 1. check and ensure you have no coolant leak 2. check intake manifold for leaks 3. check coolant level sensor it may be stuck and need to be replaced and or cleaned[/quote Thanks i well try this suggestions.
https://images.2carpros.com/forum/automotive_pictures/182800_97_chevy_malibu_ls_4d_1.jpg
Apr 24, 2008 at 3:07 PM
BMRFIXIT
  • 19,053 POSTS
steps need to be taken
4. open bleeders make sure system free of air (engine off and NOT HOT )
step was missing
Apr 24, 2008 at 10:53 PM
