2002 Chevy Malibu Sudden shotdown of power
RZMAMARIL
  • 2002 CHEVROLET MALIBU
  • 6 CYL
  • 150 MILES
My car suddenly stops (total shutdown) even when moving. My mechanic had done a computer check and I was told there was a problem with a module and I had it replaced. It was fine for about 2 weeks, however, the same problem occured this morning. It was scary for there was no control whatsoever, the brakes, the steering. Basically, it was a total shutdown.
Please help!
Tuesday, October 5th, 2010 AT 11:14 PM
KHLOW2008
  • 41,814 POSTS
Hi rzmamaril,
Thank you for the donation.
When engine shuts down, the power steering and all the items mentioned would not work correctly.
When engine stalled, were the dash indicator lights turned on?
Were you able to restart?
Is the Check Engine Lamp indicating?
What module did you replace?
Thursday, October 7th, 2010 AT 10:00 AM
RZMAMARIL
HI THERE KHLow2008,
Please see answers to your questions below:
When engine stalled, were the dash indicator lights turned on? NO
Were you able to restart? YES, I WAS ABLE TO RESTART
Is the Check Engine Lamp indicating? NO
What module did you replace? ACCORDING TO THE MECHANIC IT WAS THE MODULE UNDER THE IGNITION COIL.
Hope this is clear enough for you. Thanks
Saturday, October 9th, 2010 AT 2:26 AM
KHLOW2008
  • 41,814 POSTS
When the engine stalled and dash indicator lights do not come on, it means a power interruption has occurred.
The cause is quite likely to be ignition switch. Quite a number of ignition switch fault have been reported for this model so I would suggest getting it checked.
Saturday, October 9th, 2010 AT 5:32 AM
RZMAMARIL
Hi KHlow2008,
Yes, most probably the problem is with the ignition switch.
Saturday, October 9th, 2010 AT 10:46 PM
KHLOW2008
  • 41,814 POSTS
Keep me informed of the outcome.
Sunday, October 10th, 2010 AT 12:24 AM
Related Engine Stall While Driving Content
Code Read Retrieval/Clear Chevrolet
VIDEO
