2002 Chevy Malibu Adding Coolant
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHOTOJ7
The cap on my car's coolant expansion tank went bad, allowing all the coolant to leak out. When I went to add coolant, I noticed that there is no access to the radiator directly to add coolant. Do I just fill up the expansion tank or is there some secret radiator opening that I can't see from the top?
I just want to make sure it's topped off. I am getting ready to go on an extended drive.
Thanks!
Feb 8, 2008 at 3:08 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, it is filled at the tank. Top off and let warm up to observe the level to be sure it is full. When filling let sit for a second and purge the air before starting and capping system
Feb 9, 2008 at 12:16 AM
