2000 Chevy Malibu ignition switch
LDENOGEAN002
  • 2000 CHEVROLET MALIBU
2000 Chevy Malibu
how do I change out the ignition switch without a key?
Wednesday, March 11th, 2009 AT 2:57 AM
2CARPRO JACK
  • 11,533 POSTS
Just the tumbler part? Without a key it will have to be drilled out. This can get messy for someone that hasnt done it before, you dont want to damage the housing the tumbler goes into. There is a release located at the 4o'clock position on the housing, but for it to work the key has to be in the "run" position. Does it use the same key for the doors? If so you may want to remove a door lock and have a key made for it
Wednesday, March 11th, 2009 AT 8:07 AM
