my car will not turn off all the way. the key thing will not lock what should i do?
Oct 23, 2007 at 3:57 AM
2CARPRO JACK
✓Experienced Mechanic
Could be the ignition switch (tumbler) or the mechanical assembly behind it. Have someone look at it ASAP, you cant lock your car until it is fixed, and it will likely run the battery down over time
