2000 Chevy Malibu Flashing CEL Lean Code
ANTBALL5485
I have a 2000 Chevy Malibu with a 3.1L V6 with 139,8xx miles on it. The check engine light stays on while the car is idling but flashes when the car is moving at about 35 mph. I went to autozone to get the OBDII code read, and I got the P0171 code (fuel system for bank 1 was too lean). It shows multiple causes (O2 sensor defective, mass air flow sensor, or fuel injector problem). How do I know which problem to fix or which O2 sensor to replace? I'm in the military and can't afford to replace every part until I find the right problem. Thank you in advance for your services.
Oct 28, 2007 at 3:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:65fb9f0a2d="antball5485"]I have a 2000 Chevy Malibu with a 3.1L V6 with 139,8xx miles on it. The check engine light stays on while the car is idling but flashes when the car is moving at about 35 mph. I went to autozone to get the OBDII code read, and I got the P0171 code (fuel system for bank 1 was too lean). It shows multiple causes (O2 sensor defective, mass air flow sensor, or fuel injector problem). How do I know which problem to fix or which O2 sensor to replace? I'm in the military and can't afford to replace every part until I find the right problem. Thank you in advance for your services.[/quote:65fb9f0a2d].
Miss fire will cause check engine light to flash
So if it don’t need a tune up check for a vacuum leaks
Dec 6, 2007 at 11:00 AM
Suggested Repair
A flashing check engine light indicates a misfire. If a tune-up is not needed, check for vacuum leaks before replacing sensors or injectors.
Conversation Summary
The owner of a 2000 Chevy Malibu 3.1L reported a check engine light that stays on at idle and flashes around 35 mph, with code P0171 (bank 1 too lean). They asked how to tell whether an oxygen sensor, mass airflow sensor, or fuel injector is at fault without replacing parts at random. The expert said a flashing light is caused by a misfire and advised checking for vacuum leaks if a tune-up is not needed.
