1999 Chevy Malibu acceleration
1999 CHEVROLET MALIBU
14,400 MILES • 6 CYL • FWD • AUTOMATIC
RAMDIK11
  • 6 POSTS
i recently noticed that my engine would sound louder while accelerating,,, especially when i push down on the gas pedal,, and especially while pulling out onto the highway trying to get up to 65 mph.\
prior to this happening, i started to notice a new smell in the car especially while driving for a while on the highway. it wasn't antifreeze that much i know,,, it smelled hot and dry, almost reminded me of brake shoes,, but i've had that checked and it's not that..
then came the acceleration problems.. now it's all the time,, more noticeable when the car is hot.. and the rev noise is louder and almost sounds like an exhaust leak right under the engine, but not while idling,, only when trying to accelerate... i just had a full tune up done,, i've changed the catylitic converter,,, i just had a new muffler put on,,, a new belt.. a new water pump.. none of these things have solved the problem...
i thought maybe it was the transmission,,, and since it's sealed i can't check the fluid level,,
i did notice that i had overfilled the oil by almost a quart,, and it's been a month since i had checked it...
any suggestions on what i should do here,, it's driving me crazy
Jun 22, 2008 at 1:19 PM
RHALL77
  • 3,361 POSTS
did they replace your fuel filter. did they check your fuel pressure. is there a check engine light coming on.
Jun 23, 2008 at 4:15 AM
RAMDIK11
  • 6 POSTS
yes they did replace the fuel filter,,, no they didn't check the fuel pressure, and no there is not a check engine light on,,, there was about a month or so ago,,, and it said the egr valve was stuck open,, but i had it looked at and the guy just cleaned it out and put it back and the light went off and has been off ever since...
Jun 23, 2008 at 8:39 AM
RHALL77
  • 3,361 POSTS
i would check the fuel pressure and your fuel trims with a scan tool. these will at least tell you the fuel pressure and volume is ok
Jun 23, 2008 at 8:48 AM
