1998 Chevy Malibu
CFRINGO333
  • 1998 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 99,000 MILES
I recently had my cat converter replaced by meineke and the check engine light is back on with the same code, P0420. Do you have any idea why that could be?
Saturday, November 29th, 2008 AT 11:51 AM
DOCFIXIT
  • 18,828 POSTS
Code can be set by an out of range signal from the front O2 as to the Rear O2. Need to put on scan tool take readins may need one or both O2s. ON bank 1
Saturday, November 29th, 2008 AT 11:54 AM
CFRINGO333
  • 5 POSTS
Could the problem have been the sensor to begin with and they possibly made me change the converter for no reason?
Saturday, November 29th, 2008 AT 12:07 PM
DOCFIXIT
  • 18,828 POSTS
Really can't say would need to see emissions test and data to be sure.
Sunday, November 30th, 2008 AT 1:19 PM
CFRINGO333
  • 5 POSTS
Is it normal for the converter to be replaced and the code erased and then it comes back on saying the same error code?
Sunday, November 30th, 2008 AT 1:21 PM
DOCFIXIT
  • 18,828 POSTS
Not likely
Sunday, November 30th, 2008 AT 3:06 PM
GVAUGHN553
I had the same code like you, had a new converter put on my 98 Malibu, same code came back in a couple of days. I took it back to the same shop that put the converter on; they checked it, replaced the converter at no cost to me. It was a bad converter they put on the car. You might put the car on a rack, engine running, just tap the converter with a mallet to see if there is anything that sounds like it is lose; mine was one that could be heard when tapped.
Houston, Texas
Monday, December 1st, 2008 AT 12:57 PM
