Okay, '98 Malibu. 2.4L automatic. Car seems fine at an idle when in PARK or in NEUTRAL, but when in drive it shakes a bit and act like it might die, but doesn't die. It stutters and hesitates upon take off. The hesitation and stutters continues at lower RPMS, but it seems that if I hit the gas hard a few time it like it clears out and gets a sudden burst of speed. Check engine light is NOT on. Car acted strange and kind of had similar symptoms, but WAY WORSE BEFORE and I replaced coils, spark plugs, fuel filter and ECM. After replacing ECM before everything seemed fine. Not sure its even the same problem because before I could even get the car to do 30 it ran so bad. Any ideas?
SPONSORED LINKS
Friday, April 25th, 2008 AT 7:51 PM
