1991 Chevy Lumina Stalls After Driving
VIRGEL42
1. 1991 Chevy Lumina
2. 10000
3. automatic transmission
4. 2 wheel drive
5. Strange sounds - none
6. Fluid leaks - none
I have run out of ideas. The car will run about 15-20 miles then will stall out. If you let the car set for about 5 minutes (sometimes longer) it will start and run. This has gotten worse lately. I have changed the coil pack, it is new. The module. New computer. New ignition switch. Any suggestions would be greatly appreciated. This one has me stumped. Thank you for your time.
Jun 2, 2007 at 3:21 PM
MIKE H R
  • 3,094 POSTS
check the fuel delivery system {fuel pump, fuel filter and pressure}
Jun 3, 2007 at 3:12 AM
NICKN
  • 69 POSTS
plus the fuel lines!
Jun 11, 2007 at 2:20 PM
Suggested Repair
Check the fuel delivery system, including the fuel pump, fuel filter, fuel pressure, and fuel lines.
Conversation Summary
A 1991 Chevy Lumina stalls after about 15-20 miles and restarts after sitting for several minutes. The coil pack, ignition module, computer, and ignition switch have already been replaced. Replies recommend checking the fuel pump, fuel filter, fuel pressure, and fuel lines.
