1991 Chevy Lumina Turn Signals Won't Flash
THE PHANTOM
1991 Chevy Lumina 3.1 - 190,000 k
My signal lights will not flash. The bulbs are ok. The lights on the dash work when I move the signal arm up or down, but they will not flash when I turn the signal arm on for either a right or left hand turn. I thought it might be the flasher and I changed it but I still have the same problem, they will not flash.
Jan 28, 2007 at 10:27 AM
SERVICE WRITER
  • 9,123 POSTS
Did you change the t/s flasher or the hazard flasher?
The turn signal switch may be at fault.
Jan 28, 2007 at 10:36 AM
THE PHANTOM
Posted: Sun Jan 28, 2007 4:36 pm Post subject:
The Phantom Posted: Sun Jan 28, 2007 4:27 pm Post subject: signal lights
Reply:
I changer the signal light flasher itself. the hazard lights are working fine. Where do I find the turn signal switch, is it in the steering column?
Jan 28, 2007 at 9:29 PM
SERVICE WRITER
  • 9,123 POSTS
What I meant was that you were sure you changed the correct flasher as the are identicle.
If so, the switch sounds like the next logical spot. It is in the steerng column.
Jan 28, 2007 at 9:49 PM
THE PHANTOM
Ouch! Thanks.
Service Writer Posted: Mon Jan 29, 2007 3:49 am Post subject:
The Phantom Posted: Mon Jan 29, 2007 3:29 am Post subject: 1991 Chevy Lumina signal sights
Reply:
Service Writer Posted: Sun Jan 28, 2007 4:36 pm Post subject:
Jan 29, 2007 at 8:55 AM
Suggested Repair
Confirm the turn-signal flasher, not the identical hazard flasher, was replaced. Since the hazards work and the signals still do not flash, inspect or replace the turn signal switch in the steering column.
Conversation Summary
A 1991 Chevy Lumina owner reported that both turn signals would not flash even though the bulbs were good and the dash indicators responded to the signal lever. The owner replaced the turn-signal flasher and confirmed the hazard lights worked. The expert said the turn signal switch was the next likely cause and that it is located in the steering column.
