1997 Chevrolet Lumina Overheating
KEL
1997 lumina V6, 116,450 miles, the hot light kept coming on, and the heater don't work. Took to a shop said it was the head gasket, but it wasn't. Then they said water is leaking internally. What could the problem be??
Jun 20, 2007 at 5:09 AM
SERVICE WRITER
  • 9,123 POSTS
Intake manifold gasket most likley. Real common on these. When the coolant level drops, the heater core is emptied out, thus no heat. Don't fool around with this, get it fixed asap before the engine is ruined.
Jun 20, 2007 at 8:08 AM
Suggested Repair
Replace the intake manifold gasket promptly. A coolant leak can empty the heater core and cause overheating; delaying the repair risks engine damage.
Conversation Summary
The owner of a 1997 Chevrolet Lumina V6 reports the hot light coming on and no heater output. A shop first blamed the head gasket, then said coolant was leaking internally. The expert says a failed intake manifold gasket is the likely cause, a common issue on these engines, and advises repairing it immediately before the engine is ruined.
