Two things you must do, 1.) Get the cooling system pressure tested to find the leak, 2.) Have the codes red to determine what is stored in the PCM, probably has a little to do with the overheating, and it won't hurt to see if the cooling fan comes on when you turn on the heat.
SPONSORED LINKS
Friday, November 30th, 2007 AT 1:57 PM
