1996 Chevy Lumina engine running hot
SLATERH
  • 1996 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 176,996 MILES
I bought a 1996 chevy lumina which I thought was a good car. No leaks, test drove several times prior. Not an hour after I had it I stopped to get gas and noticed fluid just pouring out of it. Drove it half mile to repair shop and was informed the radiator had busted. Had a new one installed and mechanic said it was still running hot. Said maybe it needed a coolant sensor. Had that replaced and was assured it was fine but car still running hot. Called mechanic and he said that 1 coolant fan doesn't kick on until 225 degrees.I feel that the car overheats because the gauge gets close to 260 degrees, which is the HOT tepm. AFRAID TO DRIVE! I can't tell if the fan works at all. The air conditioner doesn't work in the car, so I know that fan #2 won't work because of that. What should I do? Can this be fixed? Would an A/C compressor fix if installed or can a rig a toggle switch resolve these issues? I'm desprate. Single mother who purcharsed car with last of $$$ PLEASE ADVISE, THANKS!
Friday, September 24th, 2010 AT 5:23 PM
Rig up a toggle switch to control the fan operation-when it gets to 220degs-turn it on till it drops to a safer zone-
Or you cane have the coolant temperature sensor and engine temperature gauge sender/switch checked out-
Saturday, September 25th, 2010 AT 1:28 AM
NICKHEADZ34
  • 62 POSTS
Replace the thermostat if you haven't already.. The passenger side fan is the coolant fan. Which should open at around 200 when the thermostat lets the hot coolant from the engine. I had a check engine light on all winter and it was a Egr code. When it got warmer I found the fan didn't kick on. Fuse was busted. And even turned the engine light out because it is same fuse for coolant fan and egr. But unless you have an check engine light that wont help. It is a great car. Take care of it. There are relays that can keep the fan from turning on also. They are in with the fuses. If the stat or fuses/relays are fine your probably better off rigging a switch and not letting someone drive it who wont pay attention the guages.(Teenagers)
Saturday, October 2nd, 2010 AT 8:26 PM
