chevy lumina 1997
CENTRONIC
My Lumina 1997, V6 3.1 148k miles surging or shaking while idle and sometime engine stop. Also with shift in parking at high revolution start voilent jerk and failing engine, this problem is present all time. When engine stop running or problem happens the only way to get away of the problem is pushing the gas pedal at high revolution for about 5 to 10 seconds, at the begining goes slow and do not respond to the aceleration and them start to respond ok. I have recently changed spark plugs, wires, crankshaft position sensor, air filter, and fuel filter. This Lumina never has a problem sinse I bought it in 2003.
I will appreciate your help because I dont want expensive repairing.
Aug 15, 2007 at 5:20 PM
SERVICE WRITER
  • 9,123 POSTS
I would start by pulling the codes from the computer.
Depending on what is or isn't there will determine the next step. You can try cleaning the egr and idle air control valves with intake cleaner. You can additionally try using seafoam in the event it is a carbon issue.
Aug 16, 2007 at 12:33 AM
CENTRONIC
[quote:13acc2c70c="Service Writer"]I would start by pulling the codes from the computer.
Depending on what is or isn't there will determine the next step. You can try cleaning the egr and idle air control valves with intake cleaner. You can additionally try using seafoam in the event it is a carbon issue.[/quote:13acc2c70c]:
I pulled out code from computer and get code for ramdon miss fire and crankshaft control sensor.
Aug 16, 2007 at 5:08 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_icm_1.jpg
Aug 16, 2007 at 1:14 PM
