Car heats up & then water leaks from the engine
KSA_WIZARD
I have a Lumina 1999; 260000km. When I start my car, engine works fine for a few minutes, but it starts getting hot soon. Once the car is very hot, coolant starts leaking with pressure from the frontal part of the engine. During this time, the fan doesn't work & further the thermo-meter doesn't show any car heat-up in its display. Please help..
Feb 24, 2007 at 6:18 PM
KIN CHAN
  • 453 POSTS
okay do this.....take a garden hose and spray it while the engine runs at idle...if it doesn't over heat then u will need to fix the fan 1st ....msg me and we'll go from there
Feb 24, 2007 at 6:52 PM
KSA_WIZARD
[quote:a932b3a039="kin chan"]okay do this.....take a garden hose and spray it while the engine runs at idle...if it doesn't over heat then u will need to fix the fan 1st ....msg me and we'll go from there[/quote:a932b3a039]
A bit confused...Is it ok to spray water on the engine? What if water falls on some electrical part? ..
Feb 24, 2007 at 7:30 PM
